![Posted Image](http://virtualdeck.com/Pictures/VirtualDeckFront.jpg)
Mimicking a turntable, VirtualDeck is designed as an aid for DJ s. It lets you fast-forward, fast-rewind, beat mix, scratch and tune an audio sample just as you would DJ on a real turntable. In some ways, it can do what no ordinary turntable can do, namely play digital samples. We're sure you at some time wished you could play your own music without having to shell out for a dub plate, or quickly cut some samples into a loop and use that to intensify or sratch on top of your set. In that case, VirtualDeck is for you.
PLEASE READ THE MANUAL on our website, http://virtualdeck.com/ to use VirtualDeck as efficiently as possible! There also a couple of VIDEO DEMOS showing the way to use the app.
The MANUAL and FAQ also cover the method to upload your OWN music.
You can download the Mac/PC client at http://virtualdeck.com/ .
AUDIO SUPPORT:
- Ogg/vorbis
- most AIFF
- most WAV
- unprotected MP3s
ADDITIONAL REQUIREMENTS:
- access to a WiFi network to upload your samples
New in this version:
- added a new screen with most features common to CD DJs! The features are:
- virtually unlimited cue points
- speed slider with 5%, 20% and 100% sensitivity
- jog wheel: release and tap the wheel to keep the current speed
- nudge buttons
- next cue, previous cue, add cue, delete cue
- stutter mode until the start button is released
- quickly skip to any part of your song by tapping the audio intensity graph
- added support for an upload tool (VirtualDeckBrowser) to more easily upload a lot of songs to VirtualDeck's library
Requirements
Compatible with iPhone and iPod touch
Requires iPhone 2.2.1 Software Update
[iTunes link - Τιμή: 5,99€]
Link removed
