PwnageTool for OS 3.0
Δημοσίευση 19/06/2009 - 19:33
1. GOLDEN RULE: If you are using a 3G iPhone with yellowsn0w and rely on yellowsn0w to obtain cellular service, then you should NOT use PwnageTool right now. UltraSn0w is not included with this release and therefore your baseband will be locked and unable to use an operator other than the official one it was bought for. UltraSn0w will be release via APT (cydia and icy) soon. If you have an original iPhone (1st generation) then 3.0 unlock works with this PwnageTool release.
2. Yellowsn0w in its current form will NOT work with the baseband version that is present in the 3.0 update, you will need Ultrasn0w, which will be released sometime soon, Ultrasn0w will work with all iPhone 3G models (but not 3GS), even ones that were previously unlockable, Ultrasn0w (when available) will be released via APT (this means you can get it via Cydia or Icy).
3. Please read all parts of this post before downloading and using these tools.
4. Read items 1, 2 and 3 again and again.
5. At the bottom of this post are the bittorrent files for the 3.0 capable version of PwnageTool.
6. This app is suitable for the recent 3.0 release.
7. PwnageTool will NOT work for the iPhone 3GS.
8. PwnageTool WILL work for Original iPhone (1st Generation), Original iPod touch (1st Generation) and the iPhone 3G.
Baseband 101
The ‘baseband’ is the generic nickname given to the internal components of the iPhone that handle the phone calls and Internet access. This ‘baseband’ is a tiny and unique independent computer system that runs inside your iPhone, it is separate to the main system that handles the applications (such as email and google maps) and it talks to the main part of the phone over an internal communications network. Think of it like a cable modem or other peripheral that is attached to your home PC that needs occasional updates. When a software update is released and presented to you within iTunes the baseband is sometimes updated (to fix bugs or add new features). The 3.0 update for the iPhone 3G contains such an update, so running the vanilla updater straight away with iTunes will reprogram and update the baseband.
SIM Free/SP Unlocked/Factory Unlocked iPhone 3G
This applies if you bought your iPhone 3G for $$$$$$$. This model of iPhone 3G doesn’t have an Service Provider lock (aka factory unlocked) and you are able to put any SIM card into the phone and get service. Your phone is already unlocked so you do not need to worry about baseband updates, simply upgrade to 3.0 using iTunes and then use PwnageTool to create an ipsw and then use this to jailbreak your phone.
iPhone 2G (1st Generation)
Update or Restore your iPhone 2G with iTunes then use PwnageTool to do the magic, ‘nuff said, you don’t need to worry about anything, the baseband will be unlocked, the phone jailbroken.
iPod Touch 1G (Original iPod Touch)
Update to 3.0 with iTunes and use PwnageTool.
iPod Touch 2G (New iPod Touch)
Sorry, no support at this time within PwnageTool, use Redsn0w instead.
Official Bittorrent Releases -
* http://torrents.thep...ay.org/4963802/
mirrorlink
Guide For 3G
Guide for 2G
Δημοσίευση 19/06/2009 - 19:43
Δημοσίευση 19/06/2009 - 19:44
Tα απαραίτητα βήματα για να κάνετε jailbreak είναι:
Πραγματοποίηση restore στην έκδοση που θέλετε αφού πρώτα έχετε κάνει backup (πληροφορίες εδώ).
Μετά σύνδεση με iTunes για να γίνει το activate.
Μετά κάνετε jailbreak με το κατάλληλο πρόγραμμα παραπάνω και μετά κάνετε το restore from backup (προαιρετικό)
SIM Free/SP Unlocked/Factory Unlocked iPhone 3G (Xρήστες iPhone από την Vodafone και Cosmote Ελλάδας)
Αν έχετε ξεκλείδωτο iPhone 3G τότε δεν θα χρειαστεί να ανησυχείτε για την αναβάθμιση της baseband στην έκδοση 3.0! Κάντε restore στην 3.0 μέσω iTunes και στη συνέχεια χρησιμοποιήστε το QuickPwn για να περάσετε γρήγορα και εύκολα τους Cydia/Icy. Οι παρακάτω κατηγορίες δεν σας απασχολούν.
Locked iPhone 3G - Preserve Baseband
Aν έχετε κλειδωμένο iPhone 3G από το εξωτερικό και θέλετε να κάνετε αναβάθμιση στην 3.0 τότε πρέπει πρώτα να αναβαθμίσετε στην 3.0 με restore και μετά να περιμένετε να χρησιμοποιήσετε το ultrasn0w
Locked iPhone 3G
Aν έχετε κλειδωμένο iPhone 3G αλλά δεν σας ενδιαφέρει το ξεκλείδωμα του, τότε κάντε restore στην 3.0 και χρησιμοποιήστε το Quickpwn για να προσθέσετε τους Cydia/Icy
Όσοι έχετε το iPhone 2G κάντε restore στην 3.0 και χρησιμοποιήστε το Quickpwn για να κάνετε jailbreak/activate/unlock
Aναβαθμίστε σε 3.0 και τρέξτε το Quickpwn
To πρόγραμμα λέγεται redsn0w
Δημοσίευση 19/06/2009 - 19:54
μπραβο στην DEV TEAM!!!
Δημοσίευση 19/06/2009 - 20:08
Δημοσίευση 19/06/2009 - 20:34
Δημοσίευση 19/06/2009 - 20:37
Δημοσίευση 19/06/2009 - 20:46
βγήκε; δεν χρειάζεται; εχασα κάτι;
Δημοσίευση 19/06/2009 - 20:49
χθες έκανα restore με το νεο firmware
μετά έκανα τις ρυθμίσεις μου (mail, contacs κτλ)
ερώτηση:
πρέπει να κάνω πάλι restore Και μετά pwnage και μετά πάλι να περάσω τις ρυθμίσεις;
ή μπορώ έτσι όπως είναι να κάνω μόνο το pwnage?
Δημοσίευση 19/06/2009 - 21:43
miPatch;
δεν του περασα τιποτα αλλο.εκανα install to installus κατεβασα μια δωρεαν εφαρμογη απο applstore και επειτα κατεβασα το παιχνιδι που ηθελα και πεζει μια χαρα.
Δημοσίευση 19/06/2009 - 22:07
Δημοσίευση 19/06/2009 - 22:09
Προσοχή όμως στα ψιλά γράμματα.....
Επίσης, αυτό δεν πρόκειται να ενεργοποιήσετε ή να ξεκλειδώσετε το iPhone. Αυτό ισχύει μόνο για τους χρήστες ΑΤΤ ...
Δημοσίευση 19/06/2009 - 22:34
Δημοσίευση 19/06/2009 - 22:41
Δημοσίευση 19/06/2009 - 22:47
