WinPwn 2.0.0.4 released! Supports iPhone firmware v2.0.1
Θέμα χωρίς απαντήσεις
Δημοσίευση 24/08/2008 - 17:31
Οι χρήστες Windows μπορούν πλέον να προβούν στην αναβάθμιση του iPhone firmware στην v2.0.1 χρησιμοποιώντας την νέα έκδοση του WinPwn 2.0.0.4!
To WinPwn 2.0.0.4 (XP & Vista 32/64-bit) υποστηρίζει root partition resizing, και φυσικά περιέχει και την πολυαναμενόμενη beta του Installer v4.0.
Notes:
- You MUST do a full uninstall of winpwn before installing the new version
- Make sure you have the latest version of iTunes ( Currently 7.7)
- WinPwn uses 300MB of ram at peak due to the ipsw being extracted in memory
- You must first click browse and load an IPSW to use WinPwn (i thought this was clear)
- For 2.0 only the *5A347_Restore.ipsw files are valid. The 345 image will not work
- If you see Failed to load image catalog/payload catalog, this is fine and won’t cause problems
- If you already have service with AT&T or other Authorized Carrier do not activate or install YouTube Fix
Donwload links:
MegaUpload Rapidshare Rapidshare.com Rapidshare.de
