* * * - - 3 ψήφοι
Jailbreak iPhone 4, iPhone 3GS Running iOS5 with Redsn0w 0.9.9b4
314 μηνύματα σε αυτό το θέμα
#1   CBSTEAM
CBSTEAM
  • 99 μηνύματα
  • Twitter:@THECBSTEAM
  • Tablet:iPad mini +4G
  • GameCenter:cbsteam
Δημοσίευση 14/10/2011 - 18:50
Κατεβάστε ανάλογα με το iPhone σας & το λογισμικό σας (Mac ή Windows) τα παρακάτω!
  • Redsn0w 0.9.9b4 (Mac and Windows)
  • iPhone 4 - iOS 5 firmware file (link)
  • iPhone 4 CDMA - iOS 5 firmware file (link)
  • iPhone 3GS - iOS 5 firmware file (link)
Update :
edit νεο update:
Update #14 [Redsn0w 0.9.9b6]: We’ve released version 0.9.9b6 of redsn0w, with both a functional fix and cosmetic fix for iOS5 jailbreakers. For iPhone3GS owners with the 06.15 baseband, this redsn0w eliminates the network crash you saw when using Location Services in iOS5 (in fact, you don’t even need to disable Location Services anymore during the initial setup). The cosmetic fix is to the visual countdown you see when going into DFU mode.
It’s okay to re-run this redsn0w over an existing device jailbroken at iOS5. Just choose “Jailbreak” again and de-select Cydia (in other words, all the checkboxes will be unchecked). If you are lucky enough to have an old-bootrom iPhone3GS, please pre-select the IPSW first (redsn0w can’t yet auto-detect the FW version of your old-bootrom 3GS if it’s already been jailbroken).
Update #15 [Redsn0w 0.9.9b7]: After some feedback on reddit, we’ve decided to make the initial jailbreak as quick as possible by no longer “stashing” the applications by default during the redsn0w run. This reduces the time to actually perform the jailbreak from 210 seconds to 80 seconds (60 percent!). However, you make up for much of that the first time you launch Cydia, which will then want to stash the applications. You can choose whether you want redsn0w or Cydia to stash in the Preferences pane.
Τελευταία επεξεργασία από: thanasis, 23/10/2011 - 10:16
#2   Dr.Konstantinos
Dr.Konstantinos
  • 221 μηνύματα
  • GameCenter:Macbook Pro 15' Retina
Δημοσίευση 15/10/2011 - 17:28
το εκανα οτι λεει ομως νομίζω εκανα μια πατατα ... οταν κατεβασα την version ios 5 την αποτηικευσα με διαφορετικο ονομα απο οτι ελεγε και μου εβγαλε ενα μηνυμα οταν πηγα να κανω την διαδικασια οτι δεν ειναι διαθεσιμη η Version Που χρησιμοποιω και κατι τετοια πατησα το just bοot μετα και κολλισε το redsnow μετα πηγα να το κανω απο την αρχη και δεν ανοιγε το redsnow και παλι ... τι να κανω?
#3   CBSTEAM
CBSTEAM
  • 99 μηνύματα
Δημοσίευση 15/10/2011 - 19:57
Καλησπέρα ...
Καταρχάς δεν νομίζω ότι το ονομα παίζει και τόσο ρόλο.. Αλλα αν θέλεις καλού κακού άλλαξε το όπως ήταν πριν.
Καταδευτερον όταν λες δεν ανοίγει; Μήπως απλα δεν σε αφήνει να πατησεις next (επειδή το error που σου έβγαλε οφειλόταν στο ότι δεν επέλεξα απο πριν το ipsw που χες κατεβάσει).
Αποσύνδεσε & ξανα συνδεστε το iPhone , τρέξε as administrator, ως διαχειριστής δηλαδή (δεξι κλικ πάνω στο reds0w) το redsn0w και πανε extras/select ipsw, επέλεξε το ipsw που κατεβασες next κτλ κτλ...
Ελπίζω να σε βοήθησαν αυτά που σου είπα!
Παραμένω στην διάθεση σου για οποιαδήποτε απορία!!!
#4   TazZ13
TazZ13
  • 53 μηνύματα
Δημοσίευση 15/10/2011 - 20:02
να κάνω μια ερώτηση.
αν περάσω την tethered, μπορώ όταν βγει η untethered να την περάσω, χωρίς να κάνω restore?
#5   CBSTEAM
CBSTEAM
  • 99 μηνύματα
Δημοσίευση 15/10/2011 - 20:04
Φυσικά... Απλα θα κανείς την διαδικασία Jb απο την αρχη!
#6   TazZ13
TazZ13
  • 53 μηνύματα
Δημοσίευση 15/10/2011 - 20:05
δηλαδή δεν χάνω κάτι από αυτά που θα περάσω έτσι;
#7   CBSTEAM
CBSTEAM
  • 99 μηνύματα
Δημοσίευση 15/10/2011 - 20:20
Όταν λες απο αυτά που θα περάσεις; Εννοείς απο το cydia? η απο το AppStore;
Αυτο που θυμάμαι παντός απο δική μου Περίπτωση παλαιότερη ΔΕΝ πειραχθηκε τίποτα απο τα tweaks του cydia που χα βάλει, τώρα δε για του AppStore δεν τίθεται καν θέμα!
#8   TazZ13
TazZ13
  • 53 μηνύματα
Δημοσίευση 15/10/2011 - 20:21
ναι, αυτά από cydia εννοώ.
#9   CBSTEAM
CBSTEAM
  • 99 μηνύματα
Δημοσίευση 15/10/2011 - 20:27
Απο παλιότερη Περίπτωση μου ΔΕΝ πειραχτηκε κάτι... Τώρα αν κάνω λάθος ας με διόρθωση κάποιος ειδικός!!!! ;-)
#10   Dr.Konstantinos
Dr.Konstantinos
  • 221 μηνύματα
Δημοσίευση 17/10/2011 - 13:06
φιλε μου το προσπαθησα πολλες φορες ετσι οπως μου το ειπες αλλα τιποτα παλι τα ιδια μου λεει ..
#11   tsip
tsip
  • 21 μηνύματα
Δημοσίευση 17/10/2011 - 13:16
δεν ειναι untethered για το 3GS με old bootrom??
#12   KostasRodos29
KostasRodos29
  • 19675 μηνύματα
Δημοσίευση 17/10/2011 - 13:18
Ναι.
#13   Ponjo
Ponjo
  • 932 μηνύματα
Δημοσίευση 17/10/2011 - 13:20
ποτε λετε να βγει κανονικο jailbrake ρε παιδια?
#14   kle
kle
  • 764 μηνύματα
  • Twitter:@akiskle
Δημοσίευση 17/10/2011 - 15:16
δλδ κανω restore, update σε ios5 μετα j/b (tethered) και περναω ξανα ΟΤΙ ειχα απο cydia, instalus και λοιπα "παρανομα" και οταν με το καλο βγει untethered j/b δε χρειαζεται να κανω παρα μονο νεο j/b και θα ειμαι οκ χωρις backup και restore?....
sorry ειμαι ασχετος αλλα προσπαθω να μαθω...
εννοητε ειμαι tethered j/b 4.3.5...
Τελευταία επεξεργασία από: kle, 17/10/2011 - 15:17
#15   nikosgnr
Δημοσίευση 17/10/2011 - 15:29
Για το Untethered, εξαρτάται απο τη συμβατότητα των εργαλείων.
Αν θα μπορείς να το περάσεις απο πάνω.
