iPhone 3GS downgrade from firmware 3.1 to 3.0
75 μηνύματα σε αυτό το θέμα
#1   thanasis
  • 9488 μηνύματα
Δημοσίευση 13/09/2009 - 02:37
[attachment=1385:Immagine-812.png]
Η λύση δεν άργησε να έρθει για τους κατοχους του 3GS που για τον οποιοδήποτε λόγο είτε κανανε update (πριν της σχετικες ανακοινώσεις) είτε αγοράσανε την συσκευή τους με το OS 3.1 δεν μπορέσανε να κάνουνε backup το ECID ....
NOTE: Ο οδηγός αναφέρεται ΑΠΟΚΛΕΙΣΤΙΚΑ σε χρήστες iPhone 3GS με OS 3.1
Apparently iH8sn0w managed to find a way to provide the ECID signed to all users who have not had time to save it. This will make it possible to downgrade your iPhone 3GS firmware from 3.1 to 3.0. What is written below is solely and exclusively for the iPhone 3GS owners who have installed by mistake firmware 3.1 and are interested in getting their certificate in order to run the Jailbreak (when it is ready to DevTeam).
To obtain your certificate file you should:
Method 1
1. Find your ECID (a 16 digit number that you can get by following this guide)
2. Once you have the number, connect to the site http://purplera1n.com and paste the figure in the black box found under the Apple logo and Microsoft, then click Enter.
3. This will help you to download a file that you send via email to this address: ih8sn0wydaz@gmail.com
4. Now you just have to wait for the response of the ih8sn0w. He will re-create the files for you IBSS, IBEC and the signed certificate.
Method 2
If the site does not work, alternatively you can use this other method to get the two files IBSS and IBEC:
1. Use IBSS & IBEC Grabber (for Mac and PC) while doing a restore of the iPhone firmware 3.1
2. When the restoration is complete you will end up with two files stored on your computer and you send them to this email address: ih8sn0wydaz@gmail.com
Within minutes you should receive back those 2 files, including digital signature that will allow you to downgrade and jailbreak when the DevTeam will release the new Tool. In other words, this guide lets you get the ECID signed to all those people who have not had time to save or who had recently bought an iPhone 3GS with firmware 3.1 already installed.
Τελευταία επεξεργασία από: iPhoneHellas, 13/09/2009 - 11:41
links added
#2   PaNoSS®
PaNoSS®
  • 158 μηνύματα
  • Κινητό: iPhone 8 Plus
Δημοσίευση 13/09/2009 - 02:47
εχω να πω λοιπον οτι εκανα οτι ακριβως λεει το alternatively και τα αποτελεσματα ειναι αυτα..
με το που τελειωσε το ρεστορε το iBEC_iBSS_Grabber δεν μου αφησε δυο αρχεια αλλα ενα φακελο με ονομα Per6.tmp με καποια αρχεια μεσα οπως αυτα που εχουν οι firmaware ispw εννοω..τελος παντων ενα φακελο 16ΜΒ περιπου δεν μου γυρισε 2 αρχεια γτ??ρεστορε σε 3.1 εκανα οπως ελεγε ο οδηγος..
υπαρχει καποιος που να το εκανε ωστε να μπορεσει να βοηθησει?και επισης στη σελιδα http://purplera1n.com πατησα τον αριθμο ECID και δεν εκανε τπτ..απλα γεμισε η μπαρα προοδου του mozilla και αυτο ηταν ολο..
Any help??
#3   taitienitsa
taitienitsa
  • 208 μηνύματα
Δημοσίευση 13/09/2009 - 03:21
Any help??
Μέσα σε αυτό τον φάκελο αν πας firmware/dfu θα δείς τα 2 αρχεία που μας ενδιαφέρουν!
#4   thanasis
  • 9488 μηνύματα
Δημοσίευση 13/09/2009 - 11:12
ετσι ακριβος..!!!
#5   PoluxGreece
PoluxGreece
  • 3100 μηνύματα
Δημοσίευση 13/09/2009 - 11:15
πιστεύω είναι το τελευτέο firmware αυτό που θα γίνει jailbreak...
έρχετε το τέλος του jailbreak
#6   thanasis
  • 9488 μηνύματα
Δημοσίευση 13/09/2009 - 11:19
δεν θελω να το πιστευω Polux :P μακαρια να βγουμε ψεφτες.
#7   PoluxGreece
PoluxGreece
  • 3100 μηνύματα
Δημοσίευση 13/09/2009 - 11:20
μακάρι φίλος αλλα το βλέπεις και μόνος σου,πρώτη φορά βλέπω την devteam έτσι να ψάχνετε τόσο καιρό,και να φτάνει σε ακρέες περιπτώσης...
#8   thanasis
  • 9488 μηνύματα
Δημοσίευση 13/09/2009 - 11:22
δικιο εχεις..!βεβεα και στα πρωτα βηματα του jailbreak ειχαμε παλι περιπου τα ιδια μεχρι να βγρουνε τους τροπους αλλα τεληκα κατι γινοτανε και μας κανανε χαρουμενους :P
#9   PoluxGreece
PoluxGreece
  • 3100 μηνύματα
Δημοσίευση 13/09/2009 - 11:23
χαχα βλέπω να γυρνάμε στα wm πάλι..
#10   gtpaonik
gtpaonik
  • 121 μηνύματα
Δημοσίευση 13/09/2009 - 11:36
αν δεν βγαλει ο geohot πρωτος η devteam τα ζωα μου αργα.....μονο αυτο το παλικαρι αξιζει!!!
#11   imposter
imposter
  • 224 μηνύματα
Δημοσίευση 13/09/2009 - 12:34
οτι κλειδωνει ειναι για να ξεκλειδωνει.
παντου υπαρχουν τρυπες και ο απανταχου ΠΑΡΟΝ geohot ειναι εδω για να τις βρισκει.
Καθε δυσκολο κλειδωμα ειναι μια νεα δοκιμασια , ετσι πιστευω οτι το βλεπει γι'αυτο και προσπαθει τοσο.
δεν μενει να κανουμε κατι αλλο απο το να περιμενουμε.
#12   ApoelAndreas
ApoelAndreas
  • 469 μηνύματα
Δημοσίευση 13/09/2009 - 12:42
Βλεπεις την DevTeam να ψαχνεται τοσο καιρο?? Χμμ.. Βγηκε πριν 4 μερες το 3.1.. Αν δεν κανω λαθος η 3.0 βγηκε 17 Ιουνιου και το Jailbreak Tool ο Geohot το εβγαλε στις 3 Ιουλιου??
#13   ellin
ellin
  • 195 μηνύματα
Δημοσίευση 13/09/2009 - 12:59
Το "ότι κλειδώνει ξεκλειδώνει" ΔΕΝ ισχύει πάντοτε!
Στην περίπτωση του iPhone 3GS είναι πιθανό να βγει Jailbreak σύντομα αλλά unlock για την τελευταία baseband μάλλον θα αργήσει αρκετά.. Μην ξεχνάτε πως η ιστορία της γάτας με το ποντίκι που παίζει η Apple με την devTeam κρατάει πολλούς μήνες και η Apple μαθαίνει συνεχώς...
Κάθε φορά που κυκλοφορεί ένα νέο εργαλείο για Jailbreak/unlock η Apple κλείνει το exploit στο επόμενο update... μετά από τόσυς μήνες έχει κλειδώσει ήδη τα περισσότερα και είναι λογικό να φτάσει κάποια στιγμή το σημείο όπου δεν θα υπάρχουν άλλα exploits...
Επίσης, πάνω στο "ότι κλειδώνει ξεκλειδώνει": ο GeoHot παιδεύεται εδώ και εβδομάδες να σπάσει το Playstation 3 (όσοι παρακολοθούν το twitter account του, το γνωρίζουν) αλλά έχει αποτύχει παταγωδώς. Αν κάποια εταιρεία μεγέθους Sony ή Apple πραγματικά αποφασίσει να κλειδώσει μία συσκευή της τα καταφέρνει.
#14   alexcary
alexcary
  • 12 μηνύματα
Δημοσίευση 13/09/2009 - 13:03
Χρησιμοποίησα τη δεύτερη μέθοδο, έχω τα αρχεία iBEC και iBSS, τα έστειλα στο ih8sn0wydaz@gmail.com, αλλά δεν πήρα απάντηση. Any suggestions?
#15   ApoelAndreas
ApoelAndreas
  • 469 μηνύματα
Δημοσίευση 13/09/2009 - 13:15
Χμμ.. Οπως λες εδω και εβδομαδες προσπαθει να σπασει το PS3.. Εδω και 3 χρονια κανεις δεν το καταφερε.. Λιγο απιστευτο δεν νομιζεις να καταφερνε να το "σπασει" σε μερικες εβδομαδες? "Αν κάποια εταιρεία μεγέθους Sony ή Apple πραγματικά αποφασίσει να κλειδώσει μία συσκευή της τα καταφέρνει." Δηλαδη τι εννοεις? Οταν ειχε σπασει το PS2, PSP, τα προηγουμενα versions του iPhone, η Apple και η Sony δεν ηθελαν να κλειδωσουν τις συσκευες τους? Απλα σιγα σιγα τα πραγματα δυσκολευουν, εγω πιστευω οτι παντα θα υπαρχει ενας τροπος να "σπασει" το καθε πραγμα, οσο χρονο και να παρει..
