iDA: turn-by-turn navigation for Europe
#16
Δημοσίευση 03/06/2009 - 23:37
κανουμε reboot και μετα fast respring απο bossprefs
βαζουμε μετα και τον χαρτη ida-europe-map-grc.deb στο var/root/media/Cydia/Autoinstall
σε μένα ετσι δουλεψε με την πρωτη!!!
αυριο θα το δοκιμασω και με το gps
Δημοσίευση 04/06/2009 - 01:53
#18
Δημοσίευση 04/06/2009 - 02:02
Quote
#19
Δημοσίευση 04/06/2009 - 08:05
#20
Δημοσίευση 04/06/2009 - 11:19
#21
Δημοσίευση 04/06/2009 - 12:57
#22
Δημοσίευση 04/06/2009 - 13:21
this is a easy but looks complicated.what this timestamp patch does is give 8 days indefinately, meaning everyday it gonna read 8 days
1. download iDA either in icy (preferred since they are big file) or cydia- repo is http://apt.ripdev.com
2. open up iDA to get ur license
3. close iDA
4. SSH into your iphone and find the iDA.app folder
5. rename the iDA file to iDA_
6. download the iDA patch file above
7. open it wordpad/notepad or any text editor
8. change the date to date you installed iDA, if u installed iDA today then use todays date
9. save the file and place in the iDA.app folder
10. set permission to 755
11. reboot your device
12. Now when u open iDA it will read 8 days left, what this timestamp patch does is give 8 days indefinately, meaning everyday it gonna read 8 days
iDA europe maps download
since downloading maps on the pc and dragging them into the iphone might be faster, here are the maps deb files
thx to villyidol for the list
to install a deb file
1.Place xxxxx.deb on your phone in /private/var/mobile if ur using terminal or /private/var/root if your using putty/winscp
2.in terminal/putty type dpkg -i xxxxx.deb (cap sensitive)
*in terminal in need to gain su root axx, so first
type root
then alpine for passsword
3.respring
iDA App:http://rapidshare.co...10-2.rar <br />
χαρτης της ελλαδος: http://rapidshare.co...e-map-grc_2.rar
[url=http://[color=red][font=Verdana][b]πηγη:http://www.xsellize.com/showthread.php?t=43055]
#23
Δημοσίευση 04/06/2009 - 13:59
#24
Δημοσίευση 04/06/2009 - 18:00
type root
3.respring
#25
Δημοσίευση 04/06/2009 - 18:59
#26
Δημοσίευση 04/06/2009 - 19:46
Πηγαίνετε στο http://poiplaza.com για Ελλάδα (το link είναι: http://poiplaza.com/....php?p=dc&c=19)
Κατεβάστε τα POI της επιλογής σας, π.χ Fix Speedcams, Greece - Attractions κ.α (σε μορφή upi [Sygic]) και εγκαταστήστε στο iDA!
- Τα .upi μπαίνουν στο /Applications/iDA.app/maps/grc
- Τα .bmp μπαίνουν στο /Applications/iDA.app/res/icons
#27
Δημοσίευση 04/06/2009 - 19:48
#28
Δημοσίευση 04/06/2009 - 20:24
Quote
Επιτέλους Ε Π Ι Τ Ε Λ Ο Υ Σ!!! Μπράβο μόνο αυτό έλειπε! Να 'στε καλα παίδες!
#29
Δημοσίευση 04/06/2009 - 20:33
#30
Δημοσίευση 04/06/2009 - 23:08
Βεβαια αργει να πιασει σημα αλλα κατα τα αλλα οκ!
Το θέμα αυτό είναι κλειδωμένο
