* * * * - 7 ψήφοι
Battery Doctor Pro
173 μηνύματα σε αυτό το θέμα
#16   Alexthekiller1993
Alexthekiller1993
  • 1515 μηνύματα
  • Twitter:@AlexNannos
  • GameCenter:Alex-the-killer
Δημοσίευση 20/03/2013 - 15:24
Εγω γτ δεν το βρισκω στο bigboss repo??
Γραψτο στο Cydia ετσι : " batterydoctorpro " και επιλεγεις το πρωτο με τα κινεζικα συμβολα μπροστα στην εκδοση 3.8.1 -294 . Δεν θα στο βγαλει πριν πατησεις search
#17   zarko11
zarko11
  • 480 μηνύματα
Δημοσίευση 20/03/2013 - 15:31
Εγινε,οκ.Ευχαριστω πολυ
#18   pavlossss
pavlossss
  • 1456 μηνύματα
Δημοσίευση 20/03/2013 - 15:50
Μερικά από τα σχόλια από το idb για το συγκεκριμένο: Αυτό με τις ip ειδικότερα
WARNINGS ABOUT BDP:
1. I used FireWall iP (tweak which checks outgoing connections from apps), and "BatteryDoctorPro" opened numerous connections, one to Beijing, and then a few to raw IP addresses. The developers have explained this is simply analytics to check daily users, but I fail to see why it would need that many connections to raw IP addresses if they already have one open to Beijing. BDP also checks your UDID, but many apps in the AppStore do as well, the main concern is the many raw IP addresses requesting to connect to your device.
2. If you have a CDMA phone, stay away from using the built in profiles (indoor/outdoor), as BDP has had issues with PERMANENTLY disabling radios (3G, LTE) to a point where restores do not fix it, and you have to manually toggle automatic carrier settings or something like that (search on reddit, there is a thread about how to fix it). And remember, if you need to restore you cannot downgrade.
PLEASE NOTE: This tweak has been the topic of discussion very frequently over on Reddit, r/jailbreak. Many people have reported some major issues with it, some resulting in people having to restore, rejailbreak, and I even saw a case where a person's phone was bricked. I believe many, if not all, of these issues have since been resolved, but I'd exercise caution in downloading this tweak.
#19   Rabb1t
Rabb1t
  • 140 μηνύματα
  • Twitter:@Giwrgos
Δημοσίευση 20/03/2013 - 15:51
Παιδιά να κλείσω κάτι για να μην τελειώνει η μπαταρία γρήγορα η να το αφήσω έτσι;
#20   MarkKnopfler
MarkKnopfler
  • 16726 μηνύματα
  • Twitter:@Fmiggas
  • GameCenter:markknopfler
Δημοσίευση 20/03/2013 - 15:52
WARNINGS ABOUT BDP:
Εγώ το έχω κανά χρόνο,δεν είχα ποτέ πρόβλημα..
#21   spyros12
spyros12
  • 151 μηνύματα
Δημοσίευση 20/03/2013 - 16:01
Εγω στο 4ς το ειχα και το εβγαλα για προβληματα μνημης. Ηταν παντα πανω απο 76% ενοειτε με ολα τα αλλα ιδια και το sbsetings εδειχνε περιπου το ιδιο οταν το εβγαλα το sbsettings εδειχνε 250 μβ ελευθερα δηλαδη 50% free ram. Mου ετρωγε δηλαδη μονιμα 25% ram!!
#22   Rabb1t
Rabb1t
  • 140 μηνύματα
  • Twitter:@Giwrgos
Δημοσίευση 20/03/2013 - 16:18
Παιδιά τι να κατέβασε καλύτερα batterypro η sbsettings?
#23   pavlossss
pavlossss
  • 1456 μηνύματα
Δημοσίευση 20/03/2013 - 16:22
Οι ip αυτές και η επικοινωνία με server και ειδικά με Ασία μεριά δεν είναι ότι καλύτερο..
#24   Rabb1t
Rabb1t
  • 140 μηνύματα
  • Twitter:@Giwrgos
Δημοσίευση 20/03/2013 - 16:24
Ξέρει κανείς ποιο θα ήταν το καλύτερο;
#25   pavlossss
pavlossss
  • 1456 μηνύματα
Δημοσίευση 20/03/2013 - 16:27
Βάλε το batterydoctor να έχεις το κεφάλι σου ήσυχο.
#26   Rabb1t
Rabb1t
  • 140 μηνύματα
  • Twitter:@Giwrgos
Δημοσίευση 20/03/2013 - 16:31
Οκ φιλαρακι το κατεβαζω και το αφήνω έτσι η κάνω και κάτι άλλο;
#27   nsxbass
nsxbass
  • 9378 μηνύματα
  • Twitter:@n1ckstrat
  • GameCenter:nsxbass
Δημοσίευση 20/03/2013 - 16:41
Κάτι έπρεπε να βρωμάει...
Φαινόταν too good to be true.
Πολύ ανησυχητικό αυτό με τις εξερχόμενες συνδέσεις προς Κίνα.
#28   guskoz
guskoz
  • 547 μηνύματα
Δημοσίευση 20/03/2013 - 16:45
Γιατί θα πρέπει να μας ανησυχήσει το παραπάνω; Προσωπικά είναι ό,τι πιο χρήσιμο είδα μετά το Zephyr! Μόλις το εγκατέστησα και νομίζω αξίζει πολύ! Θα κρατήσω προς το παρόν και το SBSettings και βλέπουμε. Κινδυνεύουμε με χρεώσεις κλπ.; Δεν κατάλαβα το πιο πάνω σχόλιο
#29   uriaman1
uriaman1
  • 478 μηνύματα
  • Twitter:@ilperfecto
  • Tablet:iPad 2 +3G
  • GameCenter:uriaman1
Δημοσίευση 20/03/2013 - 16:52
μονο κανα θεμα να ειχε να ταιριαζε λιγο πχ. στο glasklart, αλλα τεσπα.. επισης, δεν μπορουμε με καποιον τροπο να κανουμε disable στις Ασιατικες συνδεσεις?
#30   nsxbass
nsxbass
  • 9378 μηνύματα
Δημοσίευση 20/03/2013 - 16:54
Το πρόγραμμα "υπόγεια" και χωρίς να σου το λέει κάνει σύνδεση με διάφορες ip, μία εκ των οποίων και στην Κίνα.
Μιλάμε για κινητό με jailbreak, δηλαδή με πλήρως ξεκλείδωτο filesystem.
Εάν κάποιος θέλει κακόβουλα να επιτεθεί στη συσκευή σου είναι σαν να του ανοίγεις την πόρτα και να του λες "παρακαλώ περάστε".
Σαν να έχεις openssh ανοιχτό και να μην έχεις αλλάξει τον μαμά κωδικό περίπου, με τη διαφορά ότι εδώ δεν ρισκάρεις να συνδεθεί κάποιος, συνδέεται σίγουρα!
