iDA: turn-by-turn navigation for Europe
#481
Δημοσίευση 23/06/2009 - 12:44
Το ευρωπαικο.Και απο χθες οι μερες δε μειωθηκαν.Περιμενω να δω τι θα γινει και τις επομενες μερες.
Δημοσίευση 23/06/2009 - 12:56
Quote
Καλυτερα μη βαλεις το patch για το trial notification για να βλεπεις..Επισης αν μπορεις ανεβασε τον ελληνικο χαρτη σε μορφη pak.
#483
Δημοσίευση 23/06/2009 - 13:34
#484
Δημοσίευση 23/06/2009 - 13:51
#485
Δημοσίευση 23/06/2009 - 14:21
Quote
Με προλαβες...
Θα το δοκιμαζα αλλα δεν ειμαι μπροστα στο δικο μoυ pc..Απλα εγκατασταση..SSH και δοκιμαστε να βαλετε τον ελληνικο χαρτη..
Mobile Maps Australia & New Zealand - Turn-by-Turn Voice Guided GPS Navigation
Application description
Sygic GPS navigation software turns your iPhone into a real-time, turn-by-turn voice guided navigation system.
Crystal-clear animated 3D maps, fast and intuitive address search, precise route calculation, lane assistant, signpost information, notifications about upcoming petrol stations and restaurants – Sygic Mobile Maps 2009 for iPhone - is featuring all of these innovations to guide you precisely to your destination.
All maps included
The package includes the latest maps from Whereis, the leading map provider. There are no monthly fees or hidden charges.
Smooth real-time guidance
Since all maps are on your device, there is no need to download data from a cellular network. The navigation is smooth and free of any interruptions.
Landscape or portrait view
Naturally, the application includes the rotation sensor and it adapts to landscape or portrait in real time, so it doesn’t matter which way you want to use your navigation software on iPhone.
Choose your destination easily
Choose the address from history or search quickly, even with typos.
Avoid surprises
Review the list of turn instructions. They provide you with detailed overview about maneuvers on the route.
Pick your language
Software and voice instructions are localized in more than 30 languages. Latin, Cyrillic, Arabic, Greek and Thai text input methods are included.
For car or bike
Either in your car or on your bicycle, Sygic navigation system will adapt route calculation to fit your needs the best way.
Instant re-routing
Missed the turn? No worries, new route will be calculated in an instant.
Stay tuned to your progress
You are the one who says what you want to see on the main information bar – 4 spaces are free for you to choose from 10 info options, including journey time, length from or to destination, distances, speed or signal.
Find parking
Sygic Mobile Maps 2009 for iPhone will provide you with a list of nearby parking areas. Select your favorite one and you’ll be guided to it.
Stay safe all the time
The navigation system cares for your safety and provides you with information about railway crossings, safety cameras, dangerous places, speed limits and lane assistance.
Release notes
The Australia & New Zealand edition of Sygic Mobile Maps 2009 for iPhone v7.71 includes maps of Australia and New Zealand.
WhereisTM map data is ©2009 Telstra Corporation Limited and its licensors.
Sygic. The best choice for your iPhone.
New in this version Unavailable
Languages English
Requirements Compatible with iPhone and iPod touch
Requires iPhone OS 3.0 or later
#486
Δημοσίευση 23/06/2009 - 14:27
Λοιπον μολις το φορτωσα.Το προγραμμα ειναι ακριβως ιδιο με το iDa.Εχει ελληνικο μενου αλλα δυστυχως οχι ελληνικους χαρτες.Απο οτι ειδα ομως οι χαρτες εχουν την ιδια μορφη με αυτους του iDa.Ουσιαστικα το iDa δεν ειναι τιποτα αλλο απο μια custom version του Sygic,η οποια ειχε φτιαχτει απο την Ripdev.Πιστευω λοιπον πως αν φορτωσω το χαρτη τον ελληνικο θα τον παρει μια χαρα.Παω να το δοκιμασω και ξαναποσταρω σε λιγο!!!!!
#487
Δημοσίευση 23/06/2009 - 14:33
Quote
Ακου...επειδη δεν ειμαι μπροστα στο pc μου..Εγκατεστησε και iDa Europe και μετα βαλε το iDa Greece.Μπες μεσω SSH κανε αντιγραφη-επικοληση τον χαρτη σε μορφη pak.. στην επιφανεια εργασιας και μετα παλι με SSH βαλε τον χαρτη στο καινουριο(Mobile Maps Australia & New Zealand - Turn-by-Turn Voice Guided GPS Navigation) που εγκατεστησες..
#488
#489
Δημοσίευση 23/06/2009 - 14:37
Quote
Λογικα..(επειδη οπως ειπα εγω δε μπορω να μπω τωρα με SSh) πας στη διαδρομη..ΧΧΧΧ.app(δε ξερω με τι ονομα εγκαθισταται το νεο προγραμμα)/maps/...εκει μεσα θα δεις χαρτες pak...υποθετω...
Για ψαξτε το λιγο ρε παιδια..Αντε κατι εγινε παλι.."Μαννα εξ' ουρανου"..
#490
ΟΛΟΚΛΗΡΩΜΕΝ ΛΥΣΗ ΓΙΑ ΟΣΟΥΣ ΤΟΥΣ ΕΛΗΞΕ ΤΟ ΕΥΡΩΠΑΙΚΟ IDA
Το mobilenavigator προς το παρόν δεν λέει.
ΠΡΙΝ, ΤΑ ΕΧΟΥΜΕ ΣΒΗΣΕΙ ΟΛΑ ΧΑΡΤΕΣ IDA
1.το τοποθετουμε στο /private/var/root/Μedia/Cydia/AutoInstall ΤΟ ΡΩΣΙΚΟ http://rapidshare.com/files/241228559/ida-101-1.deb
Κάνουμε Reboot και καπάκι Respring.
ΤΩΡΑ ΠΑΜΕ ΝΑ ΤΟ ΑΝΟΙΞΟΥΜΕ ΠΡΙΝ ΚΑΝΟΥΜΕ ΤΑ ΠΑΡΑΚΑΤΩ ΓΙΑ ΝΑ ΠΑΡΟΥΜΕ ΕΓΚΡΙΣΗ ΤΟ ΚΛΕΙΝΟΥΜΕ.
Πηγαίνουμε /private/var/stash/Applications/iDa.app .
Μετονομάζουμε το αρχείο iDΑ σε iDA_ .
Κατεβάζουμε το αρχείο (patch) iDA και το κάνουμε επικόλληση http://rapidshare.com/files/240468002/iDA.app_2_.zip
Κάνουμε Edit το αρχείο iDA βάζοντας στη σειρά της ημερομηνίας, την ημερομηνία που το εγκαταστησαμε το iDA,π.χ. 2009-06-22
ΤΗ ΣΗΜΕΡΙΝΗ ΠΟΥ ΘΑ ΤΟ ΒΑΛΕΤΕ ΟΧΙ ΤΗΝ ΠΡΟΗΓΟΥΜΕΝΗ
Βαζουμε 0755 και "recursively" στο Properties --> Permissions.
Κάνουμε Reboot και καπάκι Respring και είμαστε έτοιμοι
κατεβασε αυτο http://rapidshare.co...4963647/rus.rar (φτιαξε ενα φακελο μετα το maps rus οπωσ παρακατω)
και βαλτο με ssh στο var/stash/application/iDA app/maps/rus οπως ειναι χωρις να το μετονομασεις (rus.pak).Ετσι ξεγελας το προγραμμα νομιζοντας οτι εχει τον ρωσικο χαρτη ενω στην πραγματικοτητα εχει τον ελληνικο.
Όλα ελιναι ελληνικά, μη φοβάστε
Μάγκες αυτό μόνο λειτουργεί και είναι προς το παρόν καλύτερο test 2.2.1 στην 3.0 δεν ξέρω
Βασικό: Ότι αλλαγές πειραματισμούς θέλετε να κάνετε μετά μόνο μέσα στο 8ήμερο γιατί μετά θα λήξει και αυτό και όχι αναβάθμιση από το Cydia
βασικα στην 3.0 το δουλευει κανεις;
για την 3 σου ειπα οτι δεν ξερω δεν μπορω να βοηθησω παραπανω
στην πρωτη σελίδα λέει οτι βάζουμε 775... τι ισχύει τελικά;
βαλε 755 οτι εγραψα και το αλλο παιζει αλλα βαλε αυτο που λεω test
ναι αυτο εβγαλε και εμενα γι αυτο ρωταω...το εχω βγαλει πλεον το source απο το cydia αλλα και παλι αμα παω να κανω update τις αλλες εφαρμογες μου βγαζει το μνμ και καλα update μπλα μπλα μπλα - remove ida τι να κανω
να βγάλεις το source απο το cydia και προσεξτε και κατι αλλο το cydia μπορει να σασ πει οτι εχει αναβαθμηση απο ενα αλλο app πχ οπωσ εμενα το boss πηγα και εγω να το κανω αλλα κατω εγραφε remove ida .μολισ το ειδα ενοειτε οτι δεν την εκανα την αναβαθμηση. για αυτο προσοχη NA KANETE UPDATE ΑΠΟ ICY KAI OΛΑ ΘΑ ΕΙΝΑΙ ΟΚ ΤΟ ΕΚΑΝΑ ΤΩΡΑ ΕΓΩ
αυτο το προγραμμα μασ αφορα ολουσ μασ γιατι ειναι μια εφαρμογη τελεια γαι το iphone θα βρεθει τελικα λυση dont worry
#491
Φιλε zakki η διαδρομη ειναι η εξης.
/private/var/mobile/Applications/A978A4EF-A821-4994-99C8-8213DBD01DAC/Sygic Australia & New Zealand.app.
Μπες εκει μεσα και περνα το ελληνικο χαρτη με την ονομασια aus.pak στον φακελο με τους χαρτες και λογικα θα δουλεψει.Δεν το εκανα ακομα γιατι τρωω σε κανα μισαωρο θα το τεσταρω και εγω και θα σου πω.
#492
Δημοσίευση 23/06/2009 - 14:40
Quote
Ωραιοςςς!!Περιμενουμε αποτελεσματα...φαε με την ησυχια σου...
Επισης για να μη μπερδευτει κανενας, η διαδρομη ειναι :
/private/var/mobile/Applications/χχχχχχχχχχχχχχχχ/Sygic Australia & New Zealand.app.
Οχι απαραιτητα : A978A4EF-A821-4994-99C8-8213DBD01DAC
#493
Δημοσίευση 23/06/2009 - 14:51
Το προγραμμα δουλευει κανονικα,πιανει σημα GPS αλλα στο χαρτη δεν εμφανιζει τπτ!
Επειδη παρατηρησα οτι εχει και αλλους χαρτες μεσα η εφαρμογη,πρέπει με καποιο τροπο να μπορεσουμε να περασουμε και το χαρτη της Ελλάδας.Να τον κανουμε εγκατασταση δηλαδη οπως καναμε στο iDA.
#494
Δημοσίευση 23/06/2009 - 15:07
Quote
Φιλε μου οντως εχει και αλλους χαρτες.Συγκερκιμενα εχει και το χαρτη της Νεας Ζηλανδιας.Δεν ξερω γιατι δεν σου δουλεψε.Εγω το τεσταρω τωρα και ποσταρω σε λιγο παλι.Πιστευω πως με καποιο τροπο θα κατφερουμε να το κανουμε να δουλεψει.Αντε να δουμε πως ομως
#495
Δημοσίευση 23/06/2009 - 15:16
Εγω πηρα το grc.pak από το iDA το μετονομασα σε aus.pak και το εβαλα μεσα στο φακελο maps/aus στη διαδρομη που αναφερεται στα πιο πανω post(με τα ιδια permissions).
Αν βρεις καποια λυση καλοδεχούμενη!
Το θέμα αυτό είναι κλειδωμένο
